  <title>CAD Forum discussion (EN) : PDF TO DWG  WITH SCALE</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : PDF TO DWG  WITH SCALE]]></description>
  <pubDate>Fri, 17 Jul 2026 06:35:33 +0000</pubDate>
  <lastBuildDate>Thu, 26 Dec 2013 23:34:29 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9796</WebWizForums:feedURL>
   <title><![CDATA[PDF TO DWG  WITH SCALE :   John Connor wrote:And if he...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25586&amp;title=pdf-to-dwg-with-scale#25586</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=413522">Robert_D</a><br /><strong>Subject:</strong> 9796<br /><strong>Posted:</strong> 26.Dec.2013 at 23:34<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by John Connor" alt="Originally posted by John Connor" style="vertical-align: text-bottom;" /> <strong>John Connor wrote:</strong><br /><br />And if he scaled by reference he'd save the cost and the time.</td></tr></table> I concur. I never use conversion soft's tedious scaling options. I prefer scaling in CAD proggie (only takes a few clicks)]]>
   <pubDate>Thu, 26 Dec 2013 23:34:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25586&amp;title=pdf-to-dwg-with-scale#25586</guid>
   <title><![CDATA[PDF TO DWG  WITH SCALE : And if he scaled by reference...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25581&amp;title=pdf-to-dwg-with-scale#25581</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9796<br /><strong>Posted:</strong> 26.Dec.2013 at 13:42<br /><br />And if he scaled by reference he'd save the cost and the time.<br>]]>
   <pubDate>Thu, 26 Dec 2013 13:42:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25581&amp;title=pdf-to-dwg-with-scale#25581</guid>
   <title><![CDATA[PDF TO DWG  WITH SCALE : you can try one raster to vector...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25580&amp;title=pdf-to-dwg-with-scale#25580</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=422437">satindra</a><br /><strong>Subject:</strong> 9796<br /><strong>Posted:</strong> 26.Dec.2013 at 12:44<br /><br />you can try one raster to vector conversion service provider.<div>The work will be accurate and on time.</div><div><br></div>]]>
   <pubDate>Thu, 26 Dec 2013 12:44:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25580&amp;title=pdf-to-dwg-with-scale#25580</guid>
   <title><![CDATA[PDF TO DWG  WITH SCALE : What program are you using to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25143&amp;title=pdf-to-dwg-with-scale#25143</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9796<br /><strong>Posted:</strong> 13.Nov.2013 at 11:32<br /><br />What program are you using to convert from a PDF to a DWG?<br>]]>
   <pubDate>Wed, 13 Nov 2013 11:32:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25143&amp;title=pdf-to-dwg-with-scale#25143</guid>
   <title><![CDATA[PDF TO DWG  WITH SCALE : Pdf to dwg with scaleHI i have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25141&amp;title=pdf-to-dwg-with-scale#25141</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=411495">CADMAN2020</a><br /><strong>Subject:</strong> 9796<br /><strong>Posted:</strong> 13.Nov.2013 at 09:02<br /><br /><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;">Pdf to dwg with scale</span><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;">HI i have a PDF drawing that needs to be conv to DWG with the wright scale&nbsp;</span><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;">the scale written on it is 1:100 when i use pDF to DWG conv prog &amp; set the Scale&nbsp;</span><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;">in the output scale box to 100 it still didn't give the wright measurements of the&nbsp;</span><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;">the rooms`s dimensions would you have way for me that i can conv PDF to DWG&nbsp;</span><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;">with scale &amp; accurate dimensions that would be so much helpful &amp; save me a lot</span><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><br style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;">of time please can you help i have a lot of this work &amp; it just take forever to resize&nbsp;</span><div><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;"><br></span></div><div><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px; line-height: normal; : rgb250, 250, 250;">every room HELP SOS&nbsp;<img src="https://www.cadforum.cz/forum_en/smileys/smiley9.gif" border="0" alt="Embarrassed" title="Embarrassed" /></span></div>]]>
   <pubDate>Wed, 13 Nov 2013 09:02:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9796&amp;PID=25141&amp;title=pdf-to-dwg-with-scale#25141</guid>
