  <title>CAD Forum discussion (EN) : Autocad map 2012</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : Autocad map 2012]]></description>
  <pubDate>Mon, 28 Sep 2026 06:30:15 +0000</pubDate>
  <lastBuildDate>Tue, 19 Nov 2013 11:24:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9812</WebWizForums:feedURL>
   <title><![CDATA[Autocad map 2012 : You&amp;#039;d better check out NOT...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9812&amp;PID=25201&amp;title=autocad-map-2012#25201</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=249910">Novarese</a><br /><strong>Subject:</strong> 9812<br /><strong>Posted:</strong> 19.Nov.2013 at 11:24<br /><br /><p>You'd better check out NOT the image coordinates, sir, but the current CRS in both main drawings (command _ADESETCRDSYS)</p><p><img src="http://sieradz.t15.org/smile.gif" border="0" /><br></p>]]>
   <pubDate>Tue, 19 Nov 2013 11:24:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9812&amp;PID=25201&amp;title=autocad-map-2012#25201</guid>
   <title><![CDATA[Autocad map 2012 : Hi,  Vector data traced on image...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9812&amp;PID=25185&amp;title=autocad-map-2012#25185</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=323093">sudhakarn</a><br /><strong>Subject:</strong> 9812<br /><strong>Posted:</strong> 16.Nov.2013 at 12:48<br /><br />Hi,<DIV>&nbsp;</DIV><DIV>Vector data traced on image in Autocad map 2005 is not matching in Autocad map 2012. I have checked image properties (coordinates ) in both versiones are same. Please help any one is there any changes in autocad 2012 version or is there any changes in settings.</DIV><DIV>&nbsp;</DIV><DIV>Thanks,</DIV><DIV>Sudhakar</DIV>]]>
   <pubDate>Sat, 16 Nov 2013 12:48:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9812&amp;PID=25185&amp;title=autocad-map-2012#25185</guid>
