  <title>CAD Forum discussion (EN) : Hyperlinks</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Hyperlinks]]></description>
  <pubDate>Wed, 04 Nov 2026 05:04:01 +0000</pubDate>
  <lastBuildDate>Thu, 16 Jan 2014 14:54:35 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9960</WebWizForums:feedURL>
   <title><![CDATA[Hyperlinks : Sure thing Syd.Sometimes it&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25697&amp;title=hyperlinks#25697</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 14:54<br /><br />Sure thing Syd.<br><br>Sometimes it's the little things that tend to trip us up.<br>]]>
   <pubDate>Thu, 16 Jan 2014 14:54:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25697&amp;title=hyperlinks#25697</guid>
   <title><![CDATA[Hyperlinks : Hello John You&amp;#039;re right...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25696&amp;title=hyperlinks#25696</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=364557">1616syd</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 14:48<br /><br />Hello John<DIV>You're right # is the culprit, yet the drawing will still open in AA in the usual manner.</DIV><DIV>When I rename the file without the prefix #, then the hyperlink opens the draawing fine.</DIV><DIV>Many thanks for your consideration and solving the problem for me.</DIV><DIV>Kindest Regards</DIV><DIV>Syd</DIV>]]>
   <pubDate>Thu, 16 Jan 2014 14:48:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25696&amp;title=hyperlinks#25696</guid>
   <title><![CDATA[Hyperlinks : Hello John No, it gets to DISK2...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25695&amp;title=hyperlinks#25695</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=364557">1616syd</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 14:43<br /><br />Hello John<DIV>No, it gets to<strong><EM> DISK2</EM></strong> and then stops, I can double click on the displayed drawing to open it;</DIV><DIV>but I shouldn't have to do that surely?</DIV><DIV>Syd</DIV>]]>
   <pubDate>Thu, 16 Jan 2014 14:43:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25695&amp;title=hyperlinks#25695</guid>
   <title><![CDATA[Hyperlinks : So you get as far as the folder...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25694&amp;title=hyperlinks#25694</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 13:57<br /><br />So you get as far as the folder which is EXISTG_DRAWINGS then it stops?<br><br>One thing came to mind.&nbsp; If the process is actually stopping at DISK2 then the &lt; <font color="#FF0000"><b>#</b></font> &gt; in the file name is probably the culprit.<br><br><strong><em><font color="#FF0000">#</font>SCHEMATIC FOR KITCHEN AREA OFFICES_18.dwg</em></strong><div>&nbsp;</div><br><span style="font-size:10px"><br /><br />Edited by John Connor - 16.Jan.2014 at 14:41</span>]]>
   <pubDate>Thu, 16 Jan 2014 13:57:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25694&amp;title=hyperlinks#25694</guid>
   <title><![CDATA[Hyperlinks : Hello John Thank you for taking...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25693&amp;title=hyperlinks#25693</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=364557">1616syd</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 13:22<br /><br />Hello John<DIV>Thank you for taking the time to consider this post.</DIV><DIV>The path/drwing&nbsp;file&nbsp;is as follows:</DIV><DIV>&nbsp;</DIV><DIV><strong><EM>C:\Documents and Settings\Syd Derbyshire\My Documents\My Pictures\IKO\WATER SUPPLY SYSTEM\EXISTG_DRAWINGS\DISK2\#SCHEMATIC FOR KITCHEN AREA OFFICES_18.dwg</EM></strong></DIV><DIV>&nbsp;</DIV><DIV>Thanks Syd</DIV>]]>
   <pubDate>Thu, 16 Jan 2014 13:22:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25693&amp;title=hyperlinks#25693</guid>
   <title><![CDATA[Hyperlinks : What&amp;#039;s the path? ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25691&amp;title=hyperlinks#25691</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 13:00<br /><br />What's the path?<br>]]>
   <pubDate>Thu, 16 Jan 2014 13:00:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25691&amp;title=hyperlinks#25691</guid>
   <title><![CDATA[Hyperlinks : Hello John I&amp;#039;ve checked...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25690&amp;title=hyperlinks#25690</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=364557">1616syd</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 12:06<br /><br />Hello John<DIV>I've checked the path time and time again, it is correct, but the link opens</DIV><DIV>only the explorer folder where the drawing lives, and doesn't open the drawing itself.</DIV><DIV><strong><EM>Syd</EM></strong></DIV><DIV><strong><EM>Lytham St Annes</EM></strong></DIV><DIV><strong><EM>UK</EM></strong></DIV>]]>
   <pubDate>Thu, 16 Jan 2014 12:06:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25690&amp;title=hyperlinks#25690</guid>
   <title><![CDATA[Hyperlinks : It sounds like you have an incomplete...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25689&amp;title=hyperlinks#25689</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 12:03<br /><br />It sounds like you have an incomplete path.<br>]]>
   <pubDate>Thu, 16 Jan 2014 12:03:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25689&amp;title=hyperlinks#25689</guid>
   <title><![CDATA[Hyperlinks : I am using AutoCAD Architecture...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25687&amp;title=hyperlinks#25687</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=364557">1616syd</a><br /><strong>Subject:</strong> 9960<br /><strong>Posted:</strong> 16.Jan.2014 at 11:58<br /><br /><FONT size=2 face="Arial, Helvetica, sans-serif">I am using AutoCAD Architecture 2014, and I want to create&nbsp;a hyperlink in a drawing</FONT><DIV><FONT size=2 face="Arial, Helvetica, sans-serif">containing&nbsp;Mtext, so that it will open another drawing which the Mtext refers to.</FONT></DIV><DIV><FONT size=3 face="Arial, Helvetica, sans-serif"><FONT size=2>So far I've only managed to create a hyperlink which opens <EM><strong>ONLY</strong></EM> the folder containing the drawing.</FONT><DIV><img src="http://www.cadforum.cz/forum_en/smileys/smiley29.gif" height="17" width="17" border="0" alt="Wacko" title="Wacko" /></DIV></FONT></DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Thu, 16 Jan 2014 11:58:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9960&amp;PID=25687&amp;title=hyperlinks#25687</guid>
