  <title>CAD Forum discussion (EN) : Export Labels</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : Export Labels]]></description>
  <pubDate>Thu, 01 Oct 2026 17:44:51 +0000</pubDate>
  <lastBuildDate>Fri, 24 Jan 2014 10:25:53 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9964</WebWizForums:feedURL>
   <title><![CDATA[Export Labels : Ain&amp;#039;t no Civil, sir, I have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9964&amp;PID=25796&amp;title=export-labels#25796</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=249910">Novarese</a><br /><strong>Subject:</strong> 9964<br /><strong>Posted:</strong> 24.Jan.2014 at 10:25<br /><br /><p>Ain't no Civil, sir, I have only Map, that's why I wrote "<strong>If</strong> you can explode"...</p><p><img src="http://sieradz.t15.org/smile.gif" height="32" width="32" border="0" /><br></p>]]>
   <pubDate>Fri, 24 Jan 2014 10:25:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9964&amp;PID=25796&amp;title=export-labels#25796</guid>
   <title><![CDATA[Export Labels : Sorry for asking a dumb question...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9964&amp;PID=25789&amp;title=export-labels#25789</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=437487">ref4ua</a><br /><strong>Subject:</strong> 9964<br /><strong>Posted:</strong> 23.Jan.2014 at 22:42<br /><br />Sorry for asking a dumb question but how do you explode the labels to simple text?<br><br>Thanks for the help.<br>]]>
   <pubDate>Thu, 23 Jan 2014 22:42:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9964&amp;PID=25789&amp;title=export-labels#25789</guid>
   <title><![CDATA[Export Labels : Sorry for the late, sir, I was...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9964&amp;PID=25747&amp;title=export-labels#25747</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=249910">Novarese</a><br /><strong>Subject:</strong> 9964<br /><strong>Posted:</strong> 22.Jan.2014 at 11:09<br /><br /><p>Sorry for the late, sir, I was sick.</p><p>If you can explode those label to simple text, you can export them to shapefile thru the _MAPEXPORT command.</p><p>In the .SHP folder, it will be created a .DBF file as well,&nbsp;readable by a spreadsheet, and containing your texts.</p><p><img src="http://sieradz.t15.org/smile.gif" border="0" /><br></p><p><br></p><p><br></p>]]>
   <pubDate>Wed, 22 Jan 2014 11:09:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9964&amp;PID=25747&amp;title=export-labels#25747</guid>
   <title><![CDATA[Export Labels : I&amp;#039;m using the label function...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9964&amp;PID=25704&amp;title=export-labels#25704</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=437487">ref4ua</a><br /><strong>Subject:</strong> 9964<br /><strong>Posted:</strong> 16.Jan.2014 at 22:21<br /><br />I'm using the label function to take measurements between locations marked by gps.&nbsp; Is there a way to export the label text to an excel file? At this point I'm having to print the map and then enter the data into excel. Sometimes there may be as many as 300+ labels. Does anyone know of a way to export this data to excel?<br><br>Thanks!<br>]]>
   <pubDate>Thu, 16 Jan 2014 22:21:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9964&amp;PID=25704&amp;title=export-labels#25704</guid>
