Discussion forum
CAD discussion |
Auto desk Map 3d Question |
Post Reply |
Author | |
dcg9981
Newbie Joined: 13.Sep.2007 Location: United States Status: Offline Points: 1 |
Topic: Auto desk Map 3d Question Posted: 13.Sep.2007 at 22:04 |
i'M NOT TO FAMILAR WITH THIS PROGRAM, HOW DO I IMPORT AN ASCII/.TXT FILE THAT HAS CO-ORDINATES ON IT INTO THIS PROGRAM. i HAVE ALOT OF FIELD WORK NEEDED TO BE LOOKED AT AND IT KEEPS SHOWING UP AS SMALL DOTS WITHOUT A POINT NUMBER OR DESCRIPTION.
D. Gallagher
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2038 |
Posted: 14.Sep.2007 at 07:30 |
It depends on the Map version. If you have the "Civil" menu in your Map, there is a point import command. Otherwise you would need to use FDO or a point import utility like ASCPOINT - see: http://www.cadforum.cz/cadforum_en/qaID.asp?tip=194
AutoCAD Map definitely needs a standard internal command to import point lists.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
Post Reply | |
Tweet
This page was generated in 0,398 seconds.
