Discussion forum
CAD discussion |
3d scan export settings to proceed in 3ds max |
Post Reply |
Author | |
Bdzelka
Newbie Joined: 20.Nov.2017 Location: Estonia Using: Solidworks2015, ArchiCAD 20, 3ds MAX 2016 Status: Offline Points: 10 |
Topic: 3d scan export settings to proceed in 3ds max Posted: 05.Dec.2017 at 14:03 |
At my work we use 3d scanners for reverse engineering. It works OK with CAD programs (Solidworks mostly).
Yesterday, I tried to import one of the scanes to 3ds max (I used obj format). The problem is that whenever I try to do something with the model, the program keeps lagging or even crashes. Other meshes works good. Maybe I should change some settings while importing. Or maybe there are any ways to optimize the mesh before export? Software I use for scanning is Artec Studio. |
Post Reply | |
Tweet
This page was generated in 0,313 seconds.
