Discussion forum
CAD discussion |
Layon command - Autocad 2015 - Doesn't still the s |
Post Reply |
Author | |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 628 |
Topic: Layon command - Autocad 2015 - Doesn't still the s Posted: 05.Feb.2018 at 20:13 |
I can't help you with that directly, but can just do whatever you want with those selected objects before turning all the other Layers back on?
ZyTenek
Newbie Joined: 05.Feb.2018 Location: Brazil Using: GstarCAD 2012 EX, AutoCAD 2015 Status: Offline Points: 2 |
Posted: 05.Feb.2018 at 14:03 |
Hello folks,
i used to use GstarCad EX 2012 a long time ago. Well, it's matter for now because here is the reason. I currently use in my job, the AutoCad 2015.
The command Layiso in Autocad can be isolate the layer that i selected, right ? or lock the others layers. So... in GstarCad EX 2012 when you put the command layiso, the layer is isolate. When you select the lines, layer, whatever... and put the command layon. The layers you've selected are still selected. But in AutoCad 2015 doesn't work like that.
When you put the command layon after layiso (configure to isolate), the layers you've selected are not selected. Can someone help me with this ? Here's a link with a video showing what am i talking: https://forums.autodesk.com/autodesk/attachments/autodesk/706/918332/1/Untitled.mp4 Thanks for attetion... |
Post Reply | |
Tweet
This page was generated in 0,504 seconds.
