CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 5613
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedExtruding with a thickness
 Post Reply Post Reply Page  12>
Author
mypushpi View Drop Down
Newbie
Newbie
Using: AutoCAD2017
Status: Offline
Direct Link To This Post Topic: Extruding with a thickness
    Posted: 08.Nov.2018 at 05:47
How to convert thick polylines to 3D solids?
A - answerPolylines with fixed width, closed polylines and circles can be converted (if the have non-zero thickness) to extruded 3D solids. Use the CONVTOSOLID command.
Pushpika
Back to Top
Newbie
Newbie
Using: AutoCAD2017
Status: Offline
Direct Link To This Post Posted: 08.Nov.2018 at 05:45
Extrude means creating solids using poly line.
If line thickness is normal or any other value, solid will create with inner core. (SOLID)
you can create shell by removing its middle core after that.
SHELL tool in 3d modelling.
I think it is equal for your requirement.
I'm sorry if I have miss understood.
Pushpika
Back to Top
Teecross View Drop Down
Newbie
Newbie
Using: Inventor2016
Status: Offline
Direct Link To This Post Posted: 07.Sep.2018 at 14:39
Sorry that I was not clear then! English is not my mothertongue ^^
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Sep.2018 at 12:56
That's but one definition.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Inventor2016
Status: Offline
Direct Link To This Post Posted: 06.Sep.2018 at 09:02
Well yeah that's what cavity is isn't it? A box without volumina on the inside with thickness on the sides
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Sep.2018 at 18:05
So what you really wanted was a hollowed out box.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Inventor2016
Status: Offline
Direct Link To This Post Posted: 05.Sep.2018 at 13:16
Yeah this is the effect but your rectangle is open on one side, i want it to be completely closed from each side.
So you have a Recangle with an inner cavity.
EDIT: I tried setting a new Work Plane behind the actual workplane and then extruding a rectangle and it works !!!! Just have to pick "Offset from Plane" and set a new plane in the thickness you need from the actual plane <3
Thanks for your help lovely dude! :)
Edited by Teecross - 05.Sep.2018 at 13:31
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Sep.2018 at 13:00
Is this the affect you are trying to achieve?  In my example the rectangle is 200x400 and has a thickness of 20.  The "cavity" is 10mm deep.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Sep.2018 at 12:31
I can't tell you how to do this using Inventor.  In AutoCAD there are a couple of ways to create a cavity in a solid object.  One way would be by subtraction.  The other way would be by using the PressPull command.  And depending on the object itself one could conceivably sweep or extrude a profile to obtain the desired result.
I tried to import the newest .ipt file but it failed for some unknown reason.  It might be an invalid file (corrupted?).
Edited by John Connor - 05.Sep.2018 at 12:52
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Inventor2016
Status: Offline
Direct Link To This Post Posted: 05.Sep.2018 at 07:04
Alright, I uploaded a new drawing, which is just a rectangular. My prior example wasn't great..
https://www.dropbox.com/s/w0nb4ic2wrh7bmd/CADForum.ipt?dl=0
So I want to extrude this rectangular with a certain thickness, i.e. 5mm from each side to the inward.
So the remaining volumen is a cavity.
I hope I expressed what I need to know ^^
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,365 seconds.
