CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Czech English Deutsch
Login/Register:
 Visitors: 3881
RSS tips RSS channel - CAD tips
RSS discussion RSS channel - CAD discussion
Discussion Discussion forum
HelpCAD discussion
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz.
Can AutoCAD do this?
 Post Reply Post Reply Page  12>
Author
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Topic: Can AutoCAD do this?
    Posted: 18.Dec.2018 at 17:09
Yes dery, if you have the AutoCAD 3D tutorial PDF by Kristen KURLAND it's in Chapter 5 - User Coordinate System.
Set UCSICON "ON" anyway.
If you have uploaded my file : 3D_SOLIDS_01.dwg you will see that I have named 3 UCS , G+ , 01 and 02 that you can restore with the command UCS , option Restore...
Take a look at the right lower corner.
If you know about UCS in 3D then it's only one direction more.
Tell me if your version of the AutoCAD 3D tutorial PDF by Kristen KURLAND has the explanation of UCS from page 36 to 49.
This tutorial is really very good.
You must know everything about UCS because you will generally work in a "XY" plane and it can be not horizontal.
When working in 3D and with SOLIDS I would recommand to "store" every step that you make for example at an exact distance of each other with ortho on ( F8 ).
Edited by philippe JOSEPH - 18.Dec.2018 at 17:22
Back to Top
dery View Drop Down
Groupie
Groupie
Using: AutoCAD 2014
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote dery Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 16:29
Originally posted by philippe JOSEPH philippe JOSEPH wrote:
If you are begining then I would recommand to learn all about UCS and Point of view.
Can you teach me how to using UCS?
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 14:31
OK dery, maybe this tutorial is not a "step by step" tutorial but it could be usefull, tell us/me if you want to know all about 3D AutoCAD.
What you can do with 2007 is 95+% of what you can do with 2013 and I think that there is a lot on the internet.
Edited by philippe JOSEPH - 18.Dec.2018 at 14:33
Back to Top
dery View Drop Down
Groupie
Groupie
Using: AutoCAD 2014
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote dery Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 14:23
With a search on the internet with : AutoCAD 3D tutorials Kristen S. KURLAND :
But it looks that you have now to register....
Thank you but, I already download it before you told me but it looks like it is not for AutoCAD 2013 instead for AutoCAD 2007.
Edited by dery - 18.Dec.2018 at 14:24
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 11:30
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 11:25
Eventually see my AutoCAD file : 3D_SOLIDS_01.dwg here in the site in the CAD/BIM Blocks library.
Launch a search with the name : 3D_SOLIDS_01
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 11:23
Dery, sory but I will only be here next january 2019 after the next hour.
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 11:21
This is the page 116.
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 11:19
This is the first page, I will try to see if it's still available on the internet, or please give me an email adress because it's a PDF.
Back to Top
dery View Drop Down
Groupie
Groupie
Using: AutoCAD 2014
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote dery Quote  Post ReplyReply Direct Link To This Post Posted: 18.Dec.2018 at 10:55
Dery, as you have AutoCAD 2014 you could eventually take a look at :
AutoCAD 3D tutorials by Kristen S. KURLAND ( AutoCAD 2013 )
Chapter 11 - Complex surfaces pages 110 to 128
See page 116 SURFNETWORK
Is this tutorial you mentioned above available for download or a book that need to be bought?
If I can download it, can you show me the link?
Have you already done some 3D works simple or complex ?
No I don't.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,109 seconds.
