Czech English Deutsch
Login/Register:
 Visitors: 3002
RSS tips RSS channel - CAD tips
RSS discussion RSS channel - CAD discussion
Discussion Discussion forum
HelpCAD discussion
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz.
Creating 3D Objects Using Scripts
 Post Reply Post Reply
Author
austindfw View Drop Down
Newbie
Newbie
Using: AutoCAD2016
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote austindfw Quote  Post ReplyReply Direct Link To This Post Topic: Creating 3D Objects Using Scripts
    Posted: 28.Dec.2018 at 02:29
I'm looking for good reference resources for creating 3D objects using scripts. Can you create cylinders, etc. using scripts?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Connor Quote  Post ReplyReply Direct Link To This Post Posted: 28.Dec.2018 at 14:40
Have you written any scripts yourself?
<<AutoCAD 2015>>
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2019
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kent Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 28.Dec.2018 at 17:19
I went to the AutoCAD Customization Forum and just put "cylinder script" in the Search window, and got >>this<<.  But another question comes to mind:  Are you asking about SCRIPTs in AutoCAD's meaning of the word?  A lot of people use the word more loosely, to refer to any kind of coded routine or function, including such things as AutoLisp routines or command macros.  But SCRIPT has a specific [and different from those] meaning in AutoCAD -- is that the one you intend?
Back to Top
Newbie
Newbie
Using: AutoCAD2016
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote austindfw Quote  Post ReplyReply Direct Link To This Post Posted: 30.Dec.2018 at 00:56
Thanks for the reply. I’m just referring to the scripts run using the SCR command. The intent is to learn the capabilities of creating and manipulating 3d objects using scripts. However, if there are other API’s that you think are better suited, please let me know.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,063 seconds.
