Discussion forum
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz. |
Draw a line starting from the midpoint of itself |
Post Reply ![]() |
Author | |
serventura ![]() Newbie ![]() Joined: 11.Dec.2018 Location: Portugal Using: Autocad2016, Inventor2016, Revit2016 Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 18.Jan.2019 at 15:07 |
Hi
Does anyone know if is possible to draw a line starting from the midpoint of itself in Autocad?
John Connor ![]() Senior Member ![]() Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 6953 |
Of what possible use would this be? And assuming the line could start at its own midpoint wouldn't it have to draw a duplicate line over itself to get to the other end? Maybe you have not worded your question correctly. Try again.
<<AutoCAD 2015>> |
philippe JOSEPH ![]() Senior Member ![]() Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1045 |
OK I also don't underdtand the use of it but you can eventually use construction lines.
Please tell use of the use of it, maybe you want to use the exact reverse direction to for example ALIGN something, I have to admit that it happens sometimes that I have to ALIGN something with existing entities and then roate the thing by 180° for the final use.
Kent Cooper ![]() Senior Member ![]() Joined: 12.Mar.2013 Location: United States Using: AutoCAD2019 Status: Offline Points: 454 |
This same question came up just a couple of weeks ago at the AutoCAD Forums -- see:
Edited by Kent Cooper - 18.Jan.2019 at 23:16 |
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,062 seconds.
