Czech English Deutsch
Login/Register:
 Visitors: 3334
RSS tips RSS channel - CAD tips
RSS discussion RSS channel - CAD discussion
Discussion Discussion forum
HelpCAD discussion
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz.
I would like to reproduce this PART if in 3D
 Post Reply Post Reply
Author
jaspion View Drop Down
Newbie
Newbie
Using: AUTOCAD 2015
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaspion Quote  Post ReplyReply Direct Link To This Post Topic: I would like to reproduce this PART if in 3D
    Posted: 01.Mar.2019 at 22:48
I would like to reproduce this part if in 3D I would like to know if someone can help me to reproduce this in 3D I will like to reproduce it with my 3D printer
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Connor Quote  Post ReplyReply Direct Link To This Post Posted: 03.Mar.2019 at 13:56
Do you have a similar part that you can take measurements from or that can be scanned so you can construct a digital 3D model?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AUTOCAD 2015
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaspion Quote  Post ReplyReply Direct Link To This Post Posted: 03.Mar.2019 at 17:57
NO I'M NOT HERE IS A MAY HAVE THE PROBLEM the messure is 40 cm long and 27 cm wide
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 04.Mar.2019 at 07:13
The part that we can see on the photo of the quad is not measuring 40 cm x 27 cm
Back to Top
Newbie
Newbie
Using: AUTOCAD 2015
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaspion Quote  Post ReplyReply Direct Link To This Post Posted: 04.Mar.2019 at 08:18
I took the measurements on the radiator that is fixed but I do not have the exact measurements
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Connor Quote  Post ReplyReply Direct Link To This Post Posted: 05.Mar.2019 at 12:08
It seems rather useless to me to attempt to reproduce a part in 3D if you don't have exact measurements.  You would be asking for trouble.  There could be conflicts with other parts and/or the mounting holes might not line up.  If either would be the case then you would have to scrap what you made and start over again.  Get the part 3D scanned.  Don't rely on hand measuring as it would be too inaccurate.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AUTOCAD 2015
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaspion Quote  Post ReplyReply Direct Link To This Post Posted: 05.Mar.2019 at 20:18
good i will print and adjust to was and measure up to have the right measures
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,063 seconds.
