CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Czech English Deutsch
Login/Register:
 Visitors: 3589
RSS tips RSS channel - CAD tips
RSS discussion RSS channel - CAD discussion
Discussion Discussion forum
HelpCAD discussion
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz.
Is it possible to make this?
 Post Reply Post Reply
Author
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Topic: Is it possible to make this?
    Posted: 01.Jun.2019 at 12:14
Hello Lion-Sage and John, eventually see this if OK on your PTC Creo as it would be done on AutoCAD.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Connor Quote  Post ReplyReply Direct Link To This Post Posted: 31.May.2019 at 12:13
Yes, it can be done.  Maybe its your approach that is flawed.  BTW..."bubbled up" is not the same as convex.
<<AutoCAD 2015>>
Back to Top
Lion-Sage View Drop Down
Newbie
Newbie
Using: PTC Creo
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lion-Sage Quote  Post ReplyReply Direct Link To This Post Posted: 30.May.2019 at 20:24
I am making funnels for a friend and he requested some interesting design what he asked is that the sides be convex (kind of bubbled up) yet keep the edges as curving inward. I have attached pictures of what I have wants to achieve. He used a lighter to heat up the plastic and try to melt it to shape to show me what he hants here is the picture. I am using PTC creo there is a surface editing tool which I can pull the surface up to a convex form but I cant keep the edges as they are. I am willing to use another cad software if it will help achieve this design.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,109 seconds.
