CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Czech English Deutsch
Login/Register:
 Visitors: 2023
RSS tips RSS channel - CAD tips
RSS discussion RSS channel - CAD discussion
Discussion Discussion forum
HelpCAD discussion
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz.
How to hatch like This. Wire pattern in Cable
 Post Reply Post Reply
Author
bsasith View Drop Down
Newbie
Newbie
Using: AutoCAD
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsasith Quote  Post ReplyReply Direct Link To This Post Topic: How to hatch like This. Wire pattern in Cable
    Posted: 02.Mar.2020 at 06:21
How to Hatch like this?  Wire patterns in Cable drawing. This is a sector cable Drawing. thanks
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 02.Mar.2020 at 07:48
Hello bsasith, I suppose that this image is what you have to draw with your AutoCAD because it's already 'hatched'.
I'm afraid this drawn with hatches would be confusing for the eyes with all that little surfaces.
The very little surfaces don't have to be hatched.
An option would be to copy/paste the image and see what's the result printed if not too dark in black and white.
Maybe color would be correct but not everybody receiving your file would appreciate.
Please show us your tests and try to apply the different correct hatches for steel, Cu ( copper ), PVC, etc...
Edited by philippe JOSEPH - 02.Mar.2020 at 07:50
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2019
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kent Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 04.Mar.2020 at 16:30
You can use my CirclesTriGridOpen pattern, part of the .zip file available at:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/creat-this-hatch/m-p/2149478/highlight/true#M252989
The diameter of the "circles" and the spacing between them are both 1 drawing unit when used at a scale of 1.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,047 seconds.
