Discussion forum
CAD discussion |
Auto Numbering |
Post Reply |
Author | |
basusumana
Newbie Joined: 11.Mar.2020 Location: United Kingdom Using: AutoCad LT2020 Status: Offline Points: 13 |
Topic: Auto Numbering Posted: 11.Mar.2020 at 16:26 |
Hello,
I want to number few circles I have in a layer. I was trying the auto number option from LT extension. I am facing a bit of difficulties: 1) How to specify the starting number? I could not understand how the autonumbering process selecting a number. I want to start from 001. 2) How to change the height of the number? How to change the font of the number? 3) The drawing I have is composed of circles which are not exactly in horizontal order or vertical order. They are circles marking piles positions in a construction site. Can I still use this autonumbering if objects are not in a particular order? Thank you, Sumana
Sumana Basu
Geophysicist Brimstone Site Investigation |
Vladimir Michl
Posted: 12.Mar.2020 at 10:09 |
Yes, you can use the autonumber function in the LT Extension.
ad 1) there is a "nn" icon in the LT Extension toolbar/ribbon where you can preset the starting number ad 2) the function uses the last text height from the TEXT command, resp. the text height as specified in the TEXTSIZE variable ad 3) yes, you click the objects (probably their CEN osnap points) individually |
Vladimir Michl (moderator)
basusumana
Posted: 12.Mar.2020 at 10:52 |
Thank you so much.
This is really helpful. Kind Regards, Sumana
Sumana Basu
Post Reply | |
Tweet
This page was generated in 0,418 seconds.
