Discussion forum
CAD discussion |
Poly line seeep prob |
Post Reply |
Author | |
2JimB
Newbie Joined: 08.Sep.2011 Location: Australia Using: Autocad 2010 Status: Offline Points: 8 |
Topic: Poly line seeep prob Posted: 02.Jan.2021 at 08:23 |
Ive been trying for hours to turn the attached into a poly line so I
can sweep. Ive done similar quite often previously ... dont know what Im
doing wrong. The files attached. If anyones willing to let me know how to rectify Id be grateful. |
JimB
2JimB
Posted: 02.Jan.2021 at 08:33 |
Its a 3D line.. |
JimB
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 02.Jan.2021 at 08:42 |
JOIN and then SPLINEDIT > Convert to Polyline seems to work fine.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
2JimB
Posted: 02.Jan.2021 at 09:28 |
Thanks Vladimir, Ill give t a crack.
much appreciated. |
JimB
2JimB
Posted: 02.Jan.2021 at 10:35 |
I didn't have any success with that process Vladimir. It keeps resisting any join on the bottom line connecting the 2 virticle bent lines. I don't know why ?
Its a 3d line Vladimir. |
JimB
Vladimir Michl
Posted: 02.Jan.2021 at 13:20 |
I have tried that on AutoCAD 2021 - maybe its JOIN command is more tolerant to entity types.
2JimB
Posted: 02.Jan.2021 at 13:59 |
Yes I found it ... id never used that before 'join' did the manual join then converted to a poly...sucessfully. I still dont understand why modify object to a poly cant work ... anyway. got there. ta.
JimB
Post Reply | |
Tweet
This page was generated in 0,418 seconds.
