CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 5117
RSS discussions
Discussion Discussion forum
HelpCAD discussion
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz.
Unistrut - Support System (For 3D Inventor)
 Post Reply Post Reply
Author
lees.fisher View Drop Down
Newbie
Newbie
Using: AutoCAD 2018, Inventor 2019, Revit 2019
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote lees.fisher Quote  Post ReplyReply Direct Link To This Post Topic: Unistrut - Support System (For 3D Inventor)
    Posted: 14.Apr.2021 at 12:13
Hi Guys,
First ever post but here goes....
I am after the 3D CAD files for Unistrut - the channels, supports and accessories (basically everything if possible)
I am designing a retrofit solution for a client and need to use this for supporting the new circuit breaker.
I have registered directly through the unistrut website but had no joy.
There is a link to the 3D CAD models, but just takes you to a list of products and you can click any links or download anything, so bit rubbish really.
I can draw each piece myself if I have the data sheets, but theres alot I need and just will take up alot of my design time.
If anyone has anything id be much abliged.
Cheers
Lee
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Connor Quote  Post ReplyReply Direct Link To This Post Posted: 15.Apr.2021 at 13:30
Try this web address... BIM/CAD Library | Unistrut
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote lees.fisher Quote  Post ReplyReply Direct Link To This Post Posted: 15.Apr.2021 at 13:33
Thanks for that - should of said it was the metric system I was after.  I found this yesterday, but metric based info seems impossible to get hold of in the same way.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,125 seconds.
