Discussion forum
CAD discussion |
Advance Steel - Export Camera Views |
Post Reply |
Author | |
rdsmax01@bigpond.com
Newbie Joined: 02.May.2022 Location: Australia Using: AutoCAD 2017, Microstation V8i SS6 Status: Offline Points: 2 |
Topic: Advance Steel - Export Camera Views Posted: 02.May.2022 at 20:27 |
How do I export a Camera View from a 3D model to Model-Space of a different dwg file. The only option I have found so far is exporting directly to Paper-Space which is contrary to my objectives.
Thank you Max
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2015 |
Posted: 04.May.2022 at 08:03 |
You can try the CopyViews tool - see https://www.cadforum.cz/en/qaID.asp?tip=6607
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
Post Reply | |
Tweet
This page was generated in 0,297 seconds.
