Discussion forum
CAD discussion |
How to delete objects the same way as extrim |
Post Reply |
Author | |
moltres1997
Newbie Joined: 18.Aug.2022 Location: Brazil Using: r033095 Status: Offline Points: 6 |
Topic: How to delete objects the same way as extrim Posted: 18.Aug.2022 at 19:51 |
Hi!
How can i erase all objects that are outside a polyline ?
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 20.Aug.2022 at 14:32 |
Use a custom lisp routine.
<<AutoCAD 2015>> |
Vladimir Michl
Posted: 22.Aug.2022 at 08:01 |
Try TrimOuter (see the Download section) or ATrim - see:
https://www.cadforum.cz/en/atrim-dynamic-trim-extend-by-painting-tip12143 |
Vladimir Michl (moderator)
moltres1997
Posted: 23.Aug.2022 at 21:51 |
Thanks ! TrimOuter is the file that i was looking for
Post Reply | |
Tweet
This page was generated in 0,477 seconds.
