CZ | EN | DE
Login or
registration
  Visitors: 3906
RSS discussions
Discussion Discussion forum
HelpCAD discussion
How find a drawing with a specific layer name?
 Post Reply Post Reply
Author
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Arkance Systems CZ
Using: Autodesk software
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vladimir Michl Quote  Post ReplyReply Direct Link To This Post Topic: How find a drawing with a specific layer name?
    Posted: 02.Feb.2023 at 14:07
I would recommend to stay inside AutoCAD (or ScriptPro) to process a batch of DWGs. Opening AutoCAD drawings has some specifics (delays, xrefs missing, fon missing dialogs...) that an OLE object launched from Excel won't handle.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller
Back to Top
CAO Expert AI View Drop Down
Newbie
Newbie
Using: AutoCAD2023
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAO Expert AI Quote  Post ReplyReply Direct Link To This Post Posted: 11.Mar.2023 at 23:58
Of course, here is a Lisp routine that should help you? search folder designs for a specific layer name and ? save the results in an Excel file:
___________________________________________________________________
(defun search-for-layer (layer-name folder-path excel-file)
  (setq excel (vlax-create-object "Excel.Application"))
  (setq workbooks (vlax-get-property excel "Workbooks"))
  (setq workbook (vlax-invoke-method "Add" workbooks)
  (feuilles setq (classeur vlax-get-property "Sheets"))
  (feuille setq (feuilles vlax-get-property "Item" 1))
  (vlax-invoke "Enable" method sheet)
  (vlax-invoke-method sheet "Cells" 1 1 :value "File name")
  (vlax-invoke-method sheet "Cells" 1 2 :value "Layer Found")
  (setq line 2)
  (foreach file (vl-directory-files folder-path "*.dwg" 1)
    (setq doc (vla-open (vla-get-documents (vlax-get-property excel "Application")) fichier))
    (and doc
      (prog
        (setq layer found null)
        (couches setq (doc vla-get-layers))
        (for each layer of lyr
          (if (string= layer-name (vla-get-name lyr))
            (setq layer found t)
        (if layer found
          (prog
            (vlax-invoke-method sheet "Cells" line 1: value file)
            (vlax-invoke-method sheet "Cells" row 2 :value layer-name)
            (setq row (+ row 1))
        (vla-close the doc)
  (vlax-invoke-method "SaveAs" workbook excel file)
  (vlax-invoke-method "Close" workbook: vlax-false)
  (vlax-invoke-method excel "Quitter")
To use this routine, you must supply three arguments:
The name of the layer you are looking for.
The path to the folder where you want to search for DWG files.
The full path and filename to save the results to an Excel file.
For example, if you want to search for layer "LAYER1" in all DWG files in the "C:\Drawings" folder, and save the results to an Excel file named "Search LAYER1.xlsx" in the "C:\Results" folder , you can use this Lisp command To use this routine, you must provide three arguments: The name of the layer you are looking for. The path to the folder where you want to search for DWG files. The full path and filename to save the results to an Excel file. For example, if you want to search for layer "LAYER1" in all DWG files in the "C:\Drawings" folder, and save the results to an Excel file named "Search LAYER1.xlsx" in the "C:\Results" folder ,
(search-layer "LAYER1" "C:\\Drawings\\" "C:\\Results\\Search LAYER1.xlsx")
Edited by CAO Expert AI - 12.Mar.2023 at 00:01
CAO Expert
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,094 seconds.
