Discussion forum
CAD discussion |
Trying to figure out LOFT command in Progecad |
Post Reply |
Author | |
masterPLans
Newbie Joined: 23.Mar.2018 Location: United States Using: autocad, softplan, Status: Offline Points: 3 |
Post Options
Thanks(0)
Posted: 26.Jan.2023 at 01:51 |
The loft command is supposed to follow a path if so chosen but I can't get it to follow the path. I pick the templates in correct order then hit enter as told in help. This is supposed to bring up another option dialog but instead a loft is created from the picked templates when I am supposed to get the option to pick guide or path. |
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1426 |
Post Options
Thanks(0)
Hello masterPLans, the LOFT command will joint 2 regions without following any path.
If you want to follow a path you will have to use SWEEP along a path or EXTRUDE with the option path. I'm not sure but those 2 commands will not allow you to get an evolutive shape along that path or it will be conformably to some AutoCAD releases. Eventually see my AutoCAD file : 3D_SOLIDS_01.dwg here in the site at the CAD/BIM Blocks library that explains the mains 3D commands.
Edited by philippe JOSEPH - 26.Jan.2023 at 08:31 |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Post Options
Thanks(0)
Did you specify a guide? Guides can be 2D polylines with a single segment, 3D polylines, lines, arcs, elliptical arcs, 2D and 3D splines and edges of entities. From the user's manual comes this bit of advice:
To create a lofted solid or surface using guidesChoose Guides. Select guide curves or [Join multiple edges]: Select guide curves to shape the loft; guide curves must intersect each cross section and begin and end at the first and last cross section. Guide curves determine the shape of the resulting three-dimensional entity. To combine multiple edges into a cross section, choose Join multiple edges, then select the edges. Edited by John Connor - 26.Jan.2023 at 16:17 |
<<AutoCAD 2015>> |
philippe JOSEPH
Post Options
Thanks(0)
Hello masterPLans and John, I have tried to have access to that guides option but only found it after the "standard" loft between 2 surfaces and it made the lofted solid disappear.
I did the test on my AutoCAD file : 3D_SOLIDS_01.dwg. I had made a 2D polyline as a guide.
philippe JOSEPH
Post Options
Thanks(0)
Hello masterPLans and John, I have place in the CAD/BIM Blocks library here in the site the AutoCAD file : VELO2009plus+.dwg to show what I can do with EXTRUDE along a path with an angle bur still don't succeed in lofting using guide...
I had made this file in 2009 of a 3D bicycle and the EXTRUDE along a path with angle is to modelize the front fork. PLZ help us.
masterPLans
Post Options
Thanks(0)
THanks for the answers. I kept working with the loft command in Prodgecad and found that a slightly less complicated example worked so I assume that my first try had an error in it. Maybe I was trying to loft an impossibility.
philippe JOSEPH
Post Options
Thanks(0)
Hello masterPLans and John, I have taken a look at the internet and found answers in a tutorial from Wolfgang WALDEN : Loft with Guides - Autocad 2020 Training - Surfaces
The "guides" are available with a right clic just after the end of the LOFT command at the right time. I thought that those guides were to LOFT along a path but it's "only" to improve the tranformation of the border of the loft from the first to the second shape, for example if your 2 shapes don't have the same number of facets. On the other hand with the LOFT command it's possible to change the "law" of the lofted shape between the 2 shapes by acting on the properties panel ( Ctrl + 1 ).
yogiji5561
Newbie Joined: 06.May.2023 Location: Algeria Using: AutoCAD2023 Status: Offline Points: 2 |
Post Options
Thanks(0)
yogiji5561
Post Options
Thanks(0)
I kept working with the loft command in Prodgecad and found that a slightly less complicated example worked so I assume that my first try had an error in it. Maybe I was trying to loft an impossibility. https://ppssppgold.one/
https://pikashow.fyi/ |
TECH 011
Groupie Joined: 18.May.2023 Location: Pakistan Using: AutoCAD2023 Status: Offline Points: 34 |
Post Options
Thanks(0)
exactly
Post Reply | |
Tweet
This page was generated in 0,502 seconds.
