Discussion forum
CAD discussion |
Crash in block editor |
Post Reply |
Author | |
Joe1969
Newbie Joined: 26.Mar.2023 Location: Mauritius Using: AotoCAD2021 Status: Offline Points: 5 |
Post Options
Thanks(0)
Posted: 26.Mar.2023 at 21:03 |
Hi everybody. Can someone help me in recovering my file. In fact my AutoCAd crashed while I was in the block editor and when I have recovered the file I see only the block without being able to exit the block editor. can soemone help pls?
J.Legrand
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1426 |
Post Options
Thanks(0)
Hello Joe1969, try the command : REFCLOSE.
Joe1969
Post Options
Thanks(0)
Hi. Thanks a lot but it does not work unfortunately.
J.Legrand
Joe1969
Post Options
Thanks(0)
When I open the file, I see only the block and the rest has disappeared but the file size is still the same.
J.Legrand
philippe JOSEPH
Post Options
Thanks(0)
REFCLOSE ?
BEDIT if you were in the block editor and not in REFEDIT. Have you launch an AUDIT on your file ? Eventually search for your ***.sv$ automatically saved files. If you have suffered a crash you should open AutoCAD and RECOVER your file.
Edited by philippe JOSEPH - 27.Mar.2023 at 10:20 |
philippe JOSEPH
Post Options
Thanks(0)
I also forgot : rename your XXX.bak in XXX-1.dwg and see what it looks inside.
See the date, hours , minutes of it.
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 627 |
Post Options
Thanks(0)
If you were in BEDIT rather than REFEDIT at the time of the crash, the command name to close that is BCLOSE. [No guarantee that it will work under the circumstances, but ....]
Joe1969
Post Options
Thanks(0)
Hi. It doesn't since it's no longer in the Block Editor. uploads/928965/Capture2.pdf
J.Legrand
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Post Options
Thanks(0)
Make sure you have your AutoCAD updated with the latest Updates and Hotfixes for your version and check if the DWG file is a real DWG file, not just a file with a .DWG extension saved by some AutoCAD clone/fake.
Edited by Vladimir Michl - 28.Mar.2023 at 16:34 |
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
MaxMax18
Newbie Joined: 04.May.2023 Location: Czech Republic Using: AutoCAD2023 Status: Offline Points: 3 |
Post Options
Thanks(0)
When AutoCAD crashes, it's bad. I'm looking for a solution to a similar problem. i hope i can find it here
Post Reply | |
Tweet
This page was generated in 0,492 seconds.
