New CADforum look launched.
Over 1.087.000 registered users (EN+CZ). Try the new Engineering calculator, the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
Discussion forum
Need Help on Drawing Dimetric Cube |
Post Reply ![]() |
Author | |
dery ![]() Senior Member ![]() Joined: 31.Jan.2018 Location: United States Using: AutoCAD 2014 Status: Offline Points: 161 |
![]() ![]() ![]() ![]() ![]() Posted: 21.Jan.2025 at 17:04 |
Anyone know what is the length of OZ using technical drawing method?
![]() Thank you Edited by dery - 21.Jan.2025 at 17:05 |
philippe JOSEPH ![]() Senior Member ![]() Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1485 |
Hello Dery, if it's a cube it will, should, would, etc... be ONE, un, A, uno, ein, etc...
The length of line OZ on the image, on 1st post is 1. Does it looks like a cube to you? It's not a cube, it look like a rectangle box to me. So? What is the correct length of line OZ using technical drawing method so that it become a cube?
Edited by dery - 24.Jan.2025 at 09:39 |
Yes it doesn't look a cube so why asking about :
Because the image on the 1st post is using Dimetric projection rule.
As you can see, the line OX and line OY form a square. Now, all I wanted to know is the length of line OZ so that it become/look like a cube.
I am asking about how to do 2D drawing of a cube using Dimetric projection.
Edited by dery - 27.Jan.2025 at 05:37 |
The internet is your friend all over the world.
https://www.youtube.com/watch?v=25_QXknJ9TI Personnaly I'm not interested in 2D drawing of 3D object anymore, 3D modeling would be an option for this and I don't think that someone already draws isometric piping schemes for example nowadays. When doing 3D you can eventually "give" your studies in 2D using the command FLATSHOT. When doing this I make a block of my 3D objects, arrange various copy of that block in at least the 3 characteristic 2D positions + some isometric view(s) at a very precise distance each other so that the FLATSHOT that I will do can be easily placed in the paper size of the project. Then a modification of the 3D object can be easily updated on the 2D. You can eventually take a look at my AutoCAD file named :
ORTHO-TO-ISO_01_B.dwgin the CAD/BIM blocks library.Edited by philippe JOSEPH - 27.Jan.2025 at 07:47 |
Vladimir Michl ![]() Moderator Group ![]() Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2076 |
There is also a very old LISP utility - DIMETRY. You can try it.
https://www.cadforum.cz/en/qaID.asp?tip=4793 |
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,100 seconds.
