Over 1.111.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
drill control |
Post Reply
| Author | |
ckemps
Newbie
Joined: 09.Aug.2023 Location: Belgium Using: autocad2023 Status: Offline Points: 2 |
Post Options
Thanks(0)
Quote Reply
Topic: drill controlPosted: 05.Sep.2025 at 13:11 |
I have a template drawing that contains a band object. This band consists of several blocks with text inside. I would like to make the entire band 5 times larger, including the text. When I try to scale the whole band at once, the software only scales the geometry but keeps the original text size defined in the blocks. So the text does not get scaled up. What I need is for both the geometry and the text inside the blocks to be scaled up by a factor of 5. Does anyone know how I can achieve this? |
julecave
Groupie
Joined: 17.Jul.2022 Location: Palestine Using: audocad 2015 Status: Offline Points: 75 |
Post Options
Thanks(0)
Quote Reply
Posted: 26.Nov.2025 at 18:26 |
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1520 |
Post Options
Thanks(1)
Quote Reply
Posted: 27.Nov.2025 at 09:36 |
Hello ckemps, please send the or a file including one of those blocks so that we can take a look but if included in a block all elements should be scaled, rotated, copied, etc..
Kent Cooper
Senior Member
Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 687 |
Post Options
Thanks(0)
Quote Reply
Posted: 01.Dec.2025 at 14:46 |
What is the Text? It sounds like it may be annotative Attributes.
Post Reply
Tweet
This page was generated in 0,113 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Topic Options
Post Options
Thanks(0)
