Over 1.128.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
| Author | |
PVEngineer
Newbie
Joined: 11.Nov.2025 Location: United States Using: AutoCAD2026 Status: Offline Points: 2 |
Topic: Can't fence select with TEXT2XLSPosted: 11.Nov.2025 at 20:36 |
Hello everyone,
I'm trying to export a large number of MTEXT object in CAD to excel using TEXT2XLS. I looked at the tutorial video on how to use it, and in the video it shows using "_fence" entered into the command prompt after starting the TEXT2XLS command to get a fence selection. I've tried doing this myself but no matter what I try I just can't seem to get a fence selection. I'm able to click on individual MTEXT objects and they'll export to the Excel file as I would expect, so the applet is functioning.
Help on this would be greatly appreciated. |
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2180 |
Posted: 11.Nov.2025 at 22:44 |
The full object selection options are available in the TXT2XLS utility - a separate, slightly different tool than the Text2XLS command in the Click2XLS utility.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
Post Reply
Tweet
This page was generated in 0,105 seconds.
Topic Options
