Over 1.115.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
How to add dynamic area text label to parcels? |
Post Reply
| Author | |
LTorino
Newbie
Joined: 03.Feb.2026 Location: Italy Using: AutoCAD Status: Offline Points: 3 |
Post Options
Thanks(0)
Quote Reply
Topic: How to add dynamic area text label to parcels?Posted: 03.Feb.2026 at 16:08 |
I would like to label a map with parcels (lots) with areas of the individual parcels. Their outlines will change so I want the label update with any change.
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2165 |
Post Options
Thanks(0)
Quote Reply
Posted: 03.Feb.2026 at 16:13 |
You can use the FIELD command and add reference to the Area property of the outline polyline. You can also use the fArea utility to simplify the process.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
LTorino
Newbie
Post Options
Thanks(0)
Quote Reply
Posted: 03.Feb.2026 at 16:53 |
Thanks!
Post Reply
Tweet
This page was generated in 0,102 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Topic Options
Post Options
Thanks(0)
