RSS discussions
Discussion Discussion forum
Progecad Help With SLICE command
 Post Reply Post Reply
Author
PanamEric View Drop Down
Newbie
Newbie
Using: Progecad 2026
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote PanamEric Quote  Post ReplyReply Direct Link To This Post Topic: Progecad Help With SLICE command
    Posted: 27.Feb.2026 at 22:21
Hello,
I am new to Progecad but am fairly familiar with Autocad.  I started with Autocad 10 and the last version I worked with was 2017.
I have been trying to use the slice command of Progecad 2026 to slice a 3D object using a circle as the slicing plane.
I don't know what I am doing wrong...I can't get it to work.
It works fine if I use a line as the slicing plane but it will not work with a circle.
my 3D solid is a + shape with a thickness of 0.05.
There are concentric circles that I am trying to use as slicing planes.
I tried a simple 2D circle it lets me select it then ask me which side to keep (i chose Both) and then nothing.  The command terminates I am back to command prompt and no slice was done.
If I try to convert the circle to a region or solid, it wont let me select it as a slicing plane.
That used to work with Autocad.
What am I doing wrong?
learned on Autocad
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,086 seconds.
