Over 1.125.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
What Drawing This Is? |
Post Reply
| Author | |
teknol
Newbie
Joined: 01.May.2026 Location: United States Status: Offline Points: 8 |
Post Options
Thanks(0)
Quote Reply
Topic: What Drawing This Is?Posted: 01.May.2026 at 18:45 |
Can anyone tell me please what drawing is this, what it's used for, and how to make and use it in Autocad? Thanks.
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1525 |
Post Options
Thanks(0)
Quote Reply
Posted: 05.May.2026 at 07:06 |
Hello teknol, were did you find this drawing ?
This drawing doesn't include the necessary dimensions to draw it on AutoCAD.
simutecra
Newbie
Joined: 05.May.2026 Location: United States Using: AutoCAD 2023, SolidWorks 2025 Status: Offline Points: 4 |
Post Options
Thanks(0)
Quote Reply
Posted: 05.May.2026 at 09:54 |
This is a geometric construction / engineering drawing, specifically it looks like a descriptive geometry layout used to define relationships between shapes (likely a circle inside a rotated square/diamond with projection lines). You’ll often see this in:
What it’s used forIt’s mainly used to:
How to make it in AutoCADYou don’t draw this as a single command, it’s built step by step:
How it’s “used” in practiceIn real CAD work, this type of drawing is more of a planning/understanding tool rather than something you deliver. Once you understand the geometry, you’d typically:
Simutecra
Post Reply
Tweet
This page was generated in 0,094 seconds.
Topic Options
Post Options
Thanks(0)
