Discussion forum
CAD discussion |
Creating Tag Blocks to Scale |
Post Reply |
Author | |
RapierTL
Newbie Joined: 07.Nov.2007 Location: United States Status: Offline Points: 3 |
Topic: Creating Tag Blocks to Scale Posted: 08.Nov.2007 at 16:18 |
bump...for my question
Vladimir Michl
Posted: 08.Nov.2007 at 09:57 |
RFA files are the "Revit families" - you can open them in Autodesk Revit.
Vladimir Michl (moderator)
ahakkimsait
Newbie Joined: 08.Nov.2007 Location: India Status: Offline Points: 3 |
Posted: 08.Nov.2007 at 09:20 |
Hai Everybody, I am Hakkim. I newly joined this forum. I want to know about RFA extention. What is the expantion of RFA ? how to open this RFA extention file? Plz Reply anyoneEdited by ahakkimsait - 08.Nov.2007 at 09:26 |
Hai Everybody
RapierTL
Posted: 07.Nov.2007 at 23:24 |
the blocks that come in the tool palette with adt 2007 work just fine. I change the scale, they insert at the correct size. It's only the blocks that i have created that come in at the same size each time.
RapierTL
Posted: 07.Nov.2007 at 21:50 |
Hi everyone,
I am fairly new to creating blocks and the such. I am trying to create tag blocks. For instance, a simple square block with dynamic attribute text. No matter what scale I am working at in model space, it inserts at the same size. The block is created at 3/32 scale since that is what we use mostly, but when I need to have a detail shot at 1/4 viewport scale, I need the block to come in much smaller. How can I create the blocks so that they are affected by the model space scale? Many thanks edit. I am using ADT 2007 Edited by RapierTL - 07.Nov.2007 at 21:54 |
Post Reply | |
Tweet
This page was generated in 0,517 seconds.
