Discussion forum
CAD discussion |
3D Studio Max Keyboard shortcuts. |
Post Reply |
Author | |
TariqRaheel
Newbie Joined: 06.Feb.2010 Location: Pakistan Status: Offline Points: 5 |
Topic: 3D Studio Max Keyboard shortcuts. Posted: 24.Jul.2010 at 07:51 |
thanks............
http://tariqraheel.wordpress.pk
KYEKWA
Newbie Joined: 22.Jul.2010 Location: Ghana Using: AutoCAD2010 Status: Offline Points: 4 |
Posted: 22.Jul.2010 at 19:23 |
Thanx
Cad64
Senior Member Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 22.Jul.2010 at 19:10 |
Rendering is a skill that takes a lot of practice, and with all the variables involved, it would be impossible to cover everything here in the forum. But the first thing you need to do is determine which rendering engine you want to learn, (Mental Ray, Vray, Other). Then I would suggest that you get yourself a good book that goes in-depth, covering all the aspects of rendering. Amazon.com is a good place to look for books.
Online Portfolio: http://www.rdeweese.com/
KYEKWA
Posted: 22.Jul.2010 at 18:41 |
Please can u help me master #D rendering?
TariqRaheel
Posted: 22.Jul.2010 at 13:56 |
nice to see this
chupalok
Groupie Joined: 20.Apr.2009 Location: Philippines Using: autocad 2012, 3dmax 2011,cs5 Status: Offline Points: 64 |
Posted: 08.Jul.2010 at 12:52 |
Its great ...thanks for posting ,It helps from other newbie
Cad64
Posted: 07.Jul.2010 at 19:02 |
Yes, these can also be found by going to your "Customize" menu and select "Customize User Interface". From here you can view all command shortcuts and change them if you so desire.
heartscool
Groupie Joined: 26.Jun.2010 Location: Pakistan Using: Autocad2006,2010 Status: Offline Points: 21 |
Posted: 07.Jul.2010 at 17:06 |
Snaps Action Table : Snap To Edge/Segment Toggle : Alt+F10 Snap To Endpoint Toggle : Alt+F8 Snap To Face Toggle : Alt+F11 Snap To Grid Points Toggle : Alt+F5 Snap To Midpoint Toggle : Alt+F9 Snap To Pivot Toggle : Alt+F6 Snap To Vertex Toggle : Alt+F7 Main UI : Adaptive Degradation Toggle : O Align : Alt+A Angle Snap Toggle : A Arc Rotate View Mode : Ctrl+R Auto Key Mode Toggle : N Background Lock Toggle : Alt+Ctrl+B Backup Time One Unit : , Bottom View : B Camera View : C Clone : Ctrl+V Cycle Active Snap Type : Alt+S Cycle Selection Method : Ctrl+F Cycle Snap Hit : Alt+Shift+S Default Lighting Toggle : Ctrl+L Delete Objects : . Disable Viewport : D Display as See-Through Toggle : Alt+X Environment Dialog Toggle : 8 Expert Mode Toggle : Ctrl+X Fetch : Alt+Ctrl+F Forward Time One Unit : . Front View : F Go to End Frame : End Go to Start Frame : Home Hide Cameras Toggle : Shift+C Hide Geometry Toggle : Shift+G Hide Grids Toggle : G Hide Helpers Toggle : Shift+H Hide Lights Toggle : Shift+L Hide Particle Systems Toggle : Shift+P Hide Shapes Toggle : Shift+S Hide Space Warps Toggle : Shift+W Hold : Alt+Ctrl+H Isometric User View : U Left View : L Lock User Interface Toggle : Alt+0 Material Editor Toggle : M Maximize Viewport Toggle : Alt+W MAXScript Listener : F11 New Scene : Ctrl+N Normal Align : Alt+N Open File : Ctrl+O Pan View : Ctrl+P Pan Viewport : I Percent Snap Toggle : Shift+Ctrl+P Perspective User View : P Place Highlight : Ctrl+H Play Animation : / Quick Align : Shift+A Quick Render : Shift+Q Redo Scene Operation : Ctrl+Y Redo Viewport Operation : Shift+Y Redraw All Views : ` Render Last : F9 Render Scene Dialog Toggle : F10 Restrict Plane Cycle : F8 Restrict to X : F5 Restrict to Y : F6 Restrict to Z : F7 Save File : Ctrl+S Scale Cycle : Ctrl+E Select All : Ctrl+A Select Ancestor : PageUp Select and Move : W Select and Rotate : E Select By Name : H Select Child : PageDown Select Children : Ctrl+PageDown Select Invert : Ctrl+I Select None : Ctrl+D Selection Lock Toggle : Space Set Key Mode : ' Set Keys : K Shade Selected Faces Toggle : F2 Show Floating Dialogs : Ctrl+` Show Main Toolbar Toggle : Alt+6 Show Safeframes Toggle : Shift+F Show Selection Bracket Toggle : J Snap To Frozen Objects Toggle : Alt+F2 Snaps Toggle : S Snaps Use Axis Constraints Toggle : Alt+D, Alt+F3 Sound Toggle : \ Spacing Tool : Shift+I Spot/Directional Light View : Shift+4 Sub-object Level Cycle : Insert Sub-object Selection Toggle : Ctrl+B Top View : T Transform Gizmo Size Down : - Transform Gizmo Size Up : = Transform Gizmo Toggle : X Transform Type-In Dialog Toggle : F12 Undo Scene Operation : Ctrl+Z Undo Viewport Operation : Shift+Z Update Background Image : Alt+Shift+Ctrl+B View Edged Faces Toggle : F4 Viewport Background : Alt+B Virtual Viewport Pan Down : NumPad 2 Virtual Viewport Pan Left : NumPad 4 Virtual Viewport Pan Right : NumPad 6 Virtual Viewport Pan Up : NumPad 8 Virtual Viewport Toggle : NumPad / Virtual Viewport Zoom In : NumPad + Virtual Viewport Zoom Out : NumPad - Wireframe / Smooth+Highlights Toggle : F3 Zoom Extents All Selected : Z Zoom Extents All : Shift+Ctrl+Z Zoom Extents : Alt+Ctrl+Z Zoom In 2X : Alt+Shift+Ctrl+Z Zoom Mode : Alt+Z Zoom Out 2X : Alt+Shift+Z Zoom Region Mode : Ctrl+W Zoom Viewport In : [, Ctrl+= Zoom Viewport Out : ], Ctrl+- Track View Add Keys : A Apply Ease Curve : Ctrl+E Apply Multiplier Curve : Ctrl+M Assign Controller : C Copy Controller : Ctrl+C Expand Object Toggle : O Expand Track Toggle : Enter, T Filters : Q Lock Selection : Space Lock Tangents Toggle : L Make Controller Unique : U Move Highlight Down : Down Arrow Move Highlight Up : Up Arrow Move Keys : M Nudge Keys Left : Left Arrow Nudge Keys Right : Right Arrow Pan : P Paste Controller : Ctrl+V Scroll Down : Ctrl+Down Arrow Scroll Up : Ctrl+Up Arrow Snap Frames : S Zoom : Z Zoom Hrizontal Extents Keys : Alt+X |
Cool Heart Models
http://www.all3dmodel.com |
Post Reply | |
Tweet
This page was generated in 0,488 seconds.
