Discussion forum
CAD discussion |
Plotter not showing up in AutoCAD 2008/2011 |
Post Reply |
Author | ||
scammc
Newbie Joined: 22.Jul.2010 Location: United States Using: Civil 3D Status: Offline Points: 2 |
Topic: Plotter not showing up in AutoCAD 2008/2011 Posted: 22.Jul.2010 at 01:52 |
Thanks for the info! Thats what I ended up doing after getting the ok from our IS people. Loaded an updated driver for the HP and it seems to be working fine and recognizing the printer in other dwgs.
MC |
Cad64
Senior Member Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 22.Jul.2010 at 01:29 | |
You will need different printer drivers. I had a lot of headaches when I upgraded my computer to 64 bit. There were a lot of issues with printing that had to be dealt with. Check your printers website for 64 bit drivers.
Online Portfolio: http://www.rdeweese.com/
scammc
Posted: 22.Jul.2010 at 00:09 | |
I would be interested in any assistance on this matter as well. Our IS people upgrade the server to a 64 bit one, we are running C3D 2009 and having the same problems. I have tried uninstalling/installing the plotter (HP 6100) and installed using the AutoCAD plotter configure, no luck.
MC |
Arben.Allaraj
Senior Member Joined: 14.Nov.2007 Location: Albania Using: AutoCAD 2008 Status: Offline Points: 602 |
Posted: 15.Jul.2010 at 20:46 | |
Have you choosed network printer option? Or all options
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com |
dmaximob
Newbie Joined: 14.Jul.2010 Location: United States Using: AutoCAD2008, AutoCAD2010 Status: Offline Points: 2 |
Posted: 15.Jul.2010 at 17:43 | |
Thanks for your suggestion. I tried removing the plotter from the computer and re-adding it using the plotter wizard. But the problem remained the same. |
Cad64
Posted: 15.Jul.2010 at 15:48 | |
You probably just need to configure a new plotter. Go to OPTIONS > Plot and Publish tab and click the "Add or Configure Plotters" button. This will open your Explorer window where you can click on the "Add-A-Plotter Wizard" to start the process.
dmaximob
Posted: 14.Jul.2010 at 18:23 | |
Our office recently had our server upgraded and now one computer cannot see
out plotter in AutoCAD. At the Plotting window, when the plotter is selected
from the Printer/plotter Name field it thinks a second then goes to None. It's
as though AutoCAD is not recognizing it.
-It is able to print from Excel. -Plotter works on all other machines in our office. -Drivers for the plotter on that machine are installed and no new driver is
available. Edited by dmaximob - 14.Jul.2010 at 18:24 |
Post Reply | |
Tweet
This page was generated in 0,453 seconds.
