CZ | EN | DE
Login or
registration
  Visitors: 6399
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedPlotter not showing up in AutoCAD 2008/2011
 Post Reply Post Reply
Author
dmaximob View Drop Down
Newbie
Newbie
Using: AutoCAD2008, AutoCAD2010
Status: Offline
Direct Link To This Post Topic: Plotter not showing up in AutoCAD 2008/2011
    Posted: 14.Jul.2010 at 18:23
Back to Top
Cad64 View Drop Down
Senior Member
Senior Member
Using: Autocad 2011, 3DS Max 2011, Photoshop CS5
Status: Offline
Direct Link To This Post Posted: 15.Jul.2010 at 15:48
You probably just need to configure a new plotter. Go to OPTIONS > Plot and Publish tab and click the "Add or Configure Plotters" button. This will open your Explorer window where you can click on the "Add-A-Plotter Wizard" to start the process.
Online Portfolio: http://www.rdeweese.com/
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 15.Jul.2010 at 17:43
 Thanks for your suggestion. I tried removing the plotter from the computer and re-adding it using the plotter wizard. But the problem remained the same.
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 15.Jul.2010 at 20:46
Have you choosed network printer option? Or all options
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
scammc View Drop Down
Newbie
Newbie
Using: Civil 3D
Status: Offline
Direct Link To This Post Posted: 22.Jul.2010 at 00:09
I would be interested in any assistance on this matter as well.  Our IS people upgrade the server to a 64 bit one, we are running C3D 2009 and having the same problems.  I have tried uninstalling/installing the plotter (HP 6100) and  installed using the AutoCAD plotter configure, no luck.
                                                         MC
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 22.Jul.2010 at 01:29
You will need different printer drivers. I had a lot of headaches when I upgraded my computer to 64 bit. There were a lot of issues with printing that had to be dealt with. Check your printers website for 64 bit drivers.
Back to Top
Newbie
Newbie
Using: Civil 3D
Status: Offline
Direct Link To This Post Posted: 22.Jul.2010 at 01:52
Thanks for the info!  Thats what I ended up doing after getting the ok from our IS people.  Loaded an updated driver  for the HP and it seems to be working fine and recognizing the printer in other dwgs.
        MC
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,348 seconds.
