Over 1.091.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
Try the new precise Engineering calculator.
New AutoCAD 2026 commands and variables.
Discussion forum
Post Reply ![]() |
Author | |
cadascadcan ![]() Newbie ![]() Joined: 13.May.2009 Location: Germany Status: Offline Points: 2 |
![]() Posted: 21.Mar.2012 at 09:04 |
Hi Folks,
I loaded this application "dynframe.vlx" (frames around text). But after starting, I get the following message:
Befehl: DYNFRAME
Replace text with framed text (mleader)
Select text/mtext to frame: *Abbruch* Fehlerhafte Zeichenfolge für ssget-Modus I use AutoCAD MEP 2012 (DACH)
What could be wrong. Is it possible that this application only works with american AutoCAD versions?
have a good time
CadAsCadCan |
Vladimir Michl ![]() Moderator Group ![]() Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2098 |
The German version of AutoCAD might have problems with the ssget mode used in the application. Please try the updated version of DynFrame available on the Download page.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
Thank you, Vladimir. Indeed this "ssget"-problem was the reason.
Now it works
![]() Greetz...
have a good time
CadAsCadCan |
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,086 seconds.
