Discussion forum
CAD discussion |
Using "Paste" in autocad |
Post Reply |
Author | |
alexia_net
Newbie Joined: 12.Sep.2007 Location: Norway Status: Offline Points: 2 |
Topic: Using "Paste" in autocad Posted: 12.Sep.2007 at 10:06 |
Hi. I want to create a script which could copy a text from a drawing file and paste it in the same drawing in a different location. How do I use "Copy" and "Paste" in VBA? Or at least how could I insert a text in a drawing using VBA? Thank you!
Edited by alexia_net - 12.Sep.2007 at 10:27 |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 12.Sep.2007 at 10:55 |
Could you use just the COPY command (not the clipboard Copy/Paste)?
Text can be added with ThisDrawing.ModelSpace.addText (see Help)
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
alexia_net
Posted: 13.Sep.2007 at 11:34 |
Hi. Thank you. I have managed to insert multi text after all. But thanks a lot.
iDraft
Newbie Joined: 21.Sep.2007 Status: Offline Points: 21 |
Posted: 21.Sep.2007 at 12:56 |
i use a lisp called TAM, and this is who put it out. it helps for text, mtext, and attributes. It's nice and fast.
Created By: Terry Miller Email: terrycadd@yahoo.com http://web2.airmail.net/terrycad |
chencos
Newbie Joined: 29.Oct.2007 Location: China Status: Offline Points: 5 |
Posted: 29.Oct.2007 at 06:26 |
very good
i am a designer
Post Reply | |
Tweet
This page was generated in 0,363 seconds.
