Print Page | Close Window
help!
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1001
Printed Date: 21.Oct.2026 at 16:12
Topic: help!
Posted By: zhb7
Subject: help!
Date Posted: 13.Aug.2008 at 16:40
Hi,
I have a lot of different files and want to put them into one file. I do not want to copy one by one. how to can use kind of way to put them together?
something like purge?
Posted By: trent.rintoul
Date Posted: 13.Aug.2008 at 17:13
What file format/program are you using?
trent.rintoul
Posted By: zhb7
Date Posted: 13.Aug.2008 at 18:13
HI
 I am using autocad 2008 lt right now
do you have any good idea to put them together ( do not want to use xref)
thks
Date Posted: 13.Aug.2008 at 18:43
You can insert the other plans as a block then explode when you have everything set if it is necessary. Other than that I don't have any other ideas but x-ref. Hope this helps some.
trent.rintoul
