Print Page | Close Window
ACad freezes when selecting text
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10021
Printed Date: 01.Oct.2026 at 05:24
Topic: ACad freezes when selecting text
Posted By: jmax1980
Subject: ACad freezes when selecting text
Date Posted: 04.Feb.2014 at 15:04
My 2012/13 AutoCAD Civil 3D Freezes when selecting text and Dimensions.... But ONLY when the properties box is up! It is driving me crazy I have been looking for solutions but have found none that have worked. So I decided to try posting my problems.
Thanks in advance.
Posted By: John Connor
Date Posted: 04.Feb.2014 at 15:12
Both programs exhibit the same behavior?
What font is being used?
Are both programs current with all service packs?
When did this problem first rear its ugly head?
<<AutoCAD 2015>>
Posted By: jmax1980
Date Posted: 04.Feb.2014 at 15:46
yes both 12 & 13 do the same thing,using a standard font (Arial)
Service packs up to date. It has been around for a while. some days worse than others. now it has become debilitating.
20+ people in the office running 12/13. I am the only one that is having the problem.
Just reinstalled 2012 with no correction. But again only happens when PROPERTEIS is open...
Date Posted: 05.Feb.2014 at 14:08
I don't run Civil 3D so I suppose there is no sense in asking to see a sample drawing.  Not sure what could be causing the problem.
Are you running anything else in conjunction with Civil 3D like some sort of add-on?
Do you use any lisp routines?
Have you made any customizations to the CUI?
<<AutoCAD 2015>>
Posted By: jmax1980
Date Posted: 06.Feb.2014 at 17:54
Turns out it was a microstation infection creating thousands of linetypes. Making the drawing bloat.
No fix for 2012. hotfix (DGNPurge) available from Autodesk for 2013/2014.
Date Posted: 06.Feb.2014 at 17:58
You are wrong.  There is a hotfix for AutoCAD 2012.  I saw it at the AutoDesk website today (11:57 a.m. EDST).
A link to get you started in the right direction:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22742673&linkID=9240617
<<AutoCAD 2015>>
