Print Page | Close Window
flatten all drawing in single command
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10094
Printed Date: 20.Oct.2026 at 03:18
Topic: flatten all drawing in single command
Posted By: deal
Subject: flatten all drawing in single command
Date Posted: 04.Mar.2014 at 20:11
morning all
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=872" rel="nofollow - How to move (flatten) entities with varying Z-coordinates to Z=0?  autocad lt 2014
i try "flatten"command but not exist in autocad lt2014
pleasee... tq..Embarrassed
Posted By: Vladimir Michl
Date Posted: 04.Mar.2014 at 23:24
You have to add the mentioned macros to your menu. They are not calling any "flatten" command.
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
Posted By: John Connor
Date Posted: 04.Mar.2014 at 23:52
Another option would be to use the old CHANGE command and the ELEVATION option.
<<AutoCAD 2015>>
Posted By: deal
Date Posted: 05.Mar.2014 at 03:32
morning Big smile
macros ????.where can i find macros menu icon or macros command ...
tq...Big smile
Date Posted: 05.Mar.2014 at 11:37
dude, buy a pair of glasses!  The link that YOU included in YOUR first post has the macros in it!  What, we have to do everything for you?  Here they are again.  I changed the color to red and made them larger so you wouldn't miss them.
Add a new macro (icon) to your toolbar - in fact two single-line macros (tool buttons) - one for selected objects and the second for all objects:
[FlattenSel]^C^C_UCS;;_select \_move _p;;0,0,1e99;;_move _p;;0,0,-1e99;;
[FlattenAll]^C^C_UCS;;_move _all;;0,0,1e99;;_move _all;;0,0,-1e99;;
_chprop;_all;;_thickness;0;;
(keep the macro text on a single line; the displayed format is to be used for old MNU/MNS files - if you add the macro through the new CUI dialog, use just its code starting with ^C)
Do not use it on 3D solids as it may distort them.
<<AutoCAD 2015>>
Posted By: rs_higgins
Date Posted: 05.Mar.2014 at 20:41
uploads/427067/flat.lsp" rel="nofollow - uploads/427067/flat.lsp
EASY John go outside and smoke a cigarette and calm you nerves.
Most AutoCad classes teach you how to draw not how to write or install macro's
Here is something you can use that will do your entire drawing.
Not just one item at a time
Flatten your drawing as though you where looking at it from the top
First you will need to load this in AutoCAD
Note where you save this file to your lisp file location> c:\lispfiles\Flat.lsp
This is where I keep all my lisp files
Then in the command line type.. (load "c:/lispfiles/flat") YEP use the parenthesis
Note use forward / when typing you file location
You can do a little research and find the lisp file location that will auto load this each time you open AutoCAD and drop the file in that folder
No electrons were harmed in the making of this post. I will admit a few protons were momentarily Inconvenienced
Date Posted: 05.Mar.2014 at 22:55
Higgy my man.  Did you happen to notice that the original poster is using AutoCAD........wait for it........LT!
As nice as that lisp might be it won't do him a bit of good.  That's why the macros (two) or the old Change command would be the first two options worth trying.  There are a couple of more LT users can try but let's not get the OP any more confused than he already is.
I don't smoke but I do inhale once in a while.
<<AutoCAD 2015>>
Date Posted: 05.Mar.2014 at 23:17
Then would you like to take some time and teach him how to use the macro's or just keep hitting when he is down. he came fro help. Not to get his glasses knocked off.
Deal: sorry I did miss the LT and John is right there the lisp will not work for you.
OK see Pup you can be funny "I don't smoke but I do inhale once in a while."                   once in a while.
Date Posted: 05.Mar.2014 at 23:29
Put your glasses on Higgy.  The instructions are given above the macro.  If the OP checks his Help files re: creating a toolbar he will find instructions courtesy of the Customization Guide that comes with AutoCAD 2014.
OK...the solution came to me in a dream last night.
Higgins will post his email address.  Deal will email him the drawings.  Higgins will flatten them using the lisp routine he mentioned then he will email the drawings back to Deal.  Deal is happy as his drawings are fixed.  Higgins is happy that he has helped a fellow human being and his place in heaven is once again assured.  And I'm happy because I had a dream that helped the both of them.
God!  It is great to be alive!
<<AutoCAD 2015>>
