Print Page | Close Window
Annotation scale - lines
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10184
Printed Date: 05.Sep.2026 at 09:20
Topic: Annotation scale - lines
Posted By: Kajito
Subject: Annotation scale - lines
Date Posted: 29.Mar.2014 at 21:56
Hi guys,
I came across another issue last week. I am starting a new project and have decided to use on this one annotation scale rather than "manual" line type change between different scales.
I had 2 different drawings in which the line scale for the same linetype had different scale for some reason. All the settings that I know of were the same - ltscale, msltscale, psltscale, units. Still the same line appeared hidden at scale 1:100 but in the other drawing it would appear hidden only at much larger scale like 1000. Eventually I copied everything from the wrong drawing into the correct one and replaced the wrong one. And it works just fine.
Any idea what did I miss? One drawing was based on Achitects dwg the other one on acad template.
Thank you
