Draftsight - making walls and scaling
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10239
Printed Date: 02.Oct.2026 at 08:19
Topic: Draftsight - making walls and scaling
Posted By: BibleBoys
Subject: Draftsight - making walls and scaling
Date Posted: 21.Apr.2014 at 18:06
Hi:
New to CAD and Draftsight. I have viewed the Draftsight videos and cannot get the same results.
1.) Trying to design a greenhouse and cannot make the offset for the walls. 2.) Trying to scale and have not figured out how to scale. I am used to selecting object and using corner handles.
Have found the buttons for both of these tasks just do not understand how to make them work.
Please advise.
------------- Alan1
Posted By: John Connor
Date Posted: 21.Apr.2014 at 18:22
Invoke the Offset command then answer the three prompts which are Specify the distance, Specify the source entity and Specify the side for the destination. So, type in a distance, pick the line you want to offset then pick the side you want to offset to. Easy.
You should be drawing everything full size not scaling it like you would on a drafting board. BTW....they are called Grips not handles. I wouldn't use a grip to scale and object; I'd type in a scale factor at the command line. You are asked to specify the entity, a basepoint and finally a scale factor.
Please pay careful attention to what is being asked on the command line.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Date Posted: 22.Apr.2014 at 02:39
I will try that. After using Photoshop and Illustrator, cad is a whole new ball game.
Thanks, Alan
------------- Alan1
