Print Page | Close Window
Problem with command "Detail"
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10350
Printed Date: 05.Sep.2026 at 05:51
Topic: Problem with command "Detail"
Posted By: Kristiansand
Subject: Problem with command "Detail"
Date Posted: 02.Jun.2014 at 16:41
Hello to all !
please can anyone help me
I  have a big problem in AutoCAD Mechanical 2012 but this is old problem from the early version,I do not know why it happens !?
Using the command "Detail" when I need a enlarge detail (scale up) available, not all objects visible in the detail that is taken out from a block,or from any other main view.Sometimes it's okay but many times is not good.
This is very frustrating, especially due, I do not know what is the reason for this
On the enlarged image Capture 02. 'll see that hiden lines missing
Best regards !
uploads/427452/Detail.zip" rel="nofollow - uploads/427452/Detail.zip
amadis
Posted By: philippe JOSEPH
Date Posted: 03.Jun.2014 at 08:05
Hello Kristiansand, I supose that you want to set correctly a detail trough a viewport, then you will have to open that viewport in the paper space, open the layers control palette and declare visible or not the layer that you want to see ( in the current viewport and not in the others ).
Date Posted: 03.Jun.2014 at 09:33
Hello Philiipe !
Thank you for quick response
I know what you're talking about but I have not explained precise. In our company
we do not use "paper space" We draw directly in "Model Space tiled"
with certain scale in predefined design space and the design limit
But at least I'll try checking layer list better, maybe something is wrong with this, or any objects  are not in the same place and direction!? I have checked this but can not see what's wrong
Many greetings from Kristiansand, Norway
amadis
Date Posted: 03.Jun.2014 at 10:11
Kristiansand, if you are drawing and printing all in the model space then you will have to set :
LTSCALE , MSLTSCALE , PSLTSCALE to see and print correctly your hidden lines and center lines.
Maybe the things that you see or not are with theses settings.
If you use blocks with hidden and center lines and copy them with different scales they should stay with the same line scale.
Do you use a "prototype file" when you begin a drawing or open AutoCAD and work with it ?
A good "prototype file" should solve problem and give you dirrectly the company lines, formats, tittle blocks, printers, SETTINGS, etc...
Posted By: John Connor
Date Posted: 03.Jun.2014 at 11:20
Drawing "to scale" in model space?  You might as well throw away your computer and go back to the drafting board.  Your company needs to take a look at paper space layouts and viewports.
<<AutoCAD 2015>>
Date Posted: 03.Jun.2014 at 16:50
Hi John !
yes this is correct for those using "Paper Space"
and I understand very well what you're talking about pga.jer have great experience
with AutoCAD drawing but more people are not accustomed to use
both space-Model and Paper Space and believe me this is much easier
using only model space with predefined prototype drawing with adjusted
scala, text, dimstyle, etc.
You know paper space, we only use for print subscription But for the large number of people in our company this is extra time getting and learn some commands as they are not vant.Jeg has worked as AutoCad course teacher and this method is that we use here in Norway
But I agree with you there are a lot of practical things using paper space and viewports.
I use this with 3d modeling when I print 2d draft of the Model
Best regards
amadis
Date Posted: 04.Jun.2014 at 13:14
I downloaded the zip file but it seems to be empty.  Where is the drawing?
<<AutoCAD 2015>>
