file opening taking long time
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10371
Printed Date: 02.Oct.2026 at 04:15
Topic: file opening taking long time
Posted By: aqeel222
Subject: file opening taking long time
Date Posted: 09.Jun.2014 at 07:17
I am using AutoCAD 2014. there is problem in few files when i open the drawing its take long time. even i use the command dgnpurge. but still problem. is there any good solution to solve this problem.
Posted By: John Connor
Date Posted: 09.Jun.2014 at 11:40
Did you use the command line version of AutoCAD's Purge command that is preceded by a dash like this:
-purge
...then purge Regapps first?
Did you then follow that up using the same command but doing a Purge > All?
Did you run an Audit on the drawing?
Are xrefs being used?
Are layer filters being used?
Does your system meet the minimum recommended specifications as set forth by AutoDesk?
Are you working with a networked version of AutoCAD or a standalone version?
Is your program up to date with all service packs?
Are you seeing any error messages?
Have you checked the paths to all support files?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
