Print Page | Close Window
acad hatch pattern
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1038
Printed Date: 05.Sep.2026 at 07:22
Topic: acad hatch pattern
Posted By: gapb
Subject: acad hatch pattern
Date Posted: 22.Aug.2008 at 14:24
I edited the acad.pat file and added new hatch patterns, deleted al the standard predefined hatches, so far so good, but now i get the message "error reading pattern file". I located the problem and it has everything to do with the predefined standard "ANGLE" hatch pattern. If i put this hatch back in the file everything works perfect and no errors. If i change hatch but keep same name everything works. When i the move the hatch to the end of the file it still works. I found out that when i hatch it always starts with the angle hatch so i guess there is alink somewhere that tells autocad to look for the angle hatch first. And this is exactly my question, how can i make the acadiso.pat work without any of the standard patterns without any error, can anyone help me with this?
Posted By: PepaR
Date Posted: 26.Aug.2008 at 00:36
Please, verify syntax of file and check hatch patterns for duplicity.
PepaR
Posted By: gapb
Date Posted: 26.Aug.2008 at 08:55
already done that, no problems. the problem occurs when you delete the "angle" hatch from the standard file as when just installed.
