Print Page | Close Window
Can´t seem to get it right with rendering in auto
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10386
Printed Date: 11.Jul.2026 at 11:19
Topic: Can´t seem to get it right with rendering in auto
Posted By: miroslav_s
Subject: Can´t seem to get it right with rendering in auto
Date Posted: 15.Jun.2014 at 11:30
<a href="http://www.tenlinks.com/banmanpro/ad.aspx?ZoneID=500&amp;Task=Click&amp;Mode=HTML&amp;SiteID=1&amp;PageID=33530"> <img src="http://www.tenlinks.com/banmanpro/ad.aspx?ZoneID=500&amp;Task=Get&amp;Mode=HTML&amp;SiteID=1&amp;PageID=33530" width="300" height="250" border="0" alt=""></a>
Hi,
I really don´t get it. What am I doing wrong? I get wrong result when rendering.I put two links so that you can see what I mean. The first link( http://prntscr.com/3sureb" rel="nofollow - - ) is showing theobject (car) as it looks like in autocad when I work with it and here it lookjust fine. As materials I used PLASTIC LATEX ( http://prntscr.com/3sv24a" rel="nofollow - - ) and PLASTIC RED ON ( http://prntscr.com/3sv2bq" rel="nofollow - - ) . The reason Iused high transparency for material Latex is so that the brakingsystem on thecar can be seen better. BUT as you can see the result is very bad http://prntscr.com/3suyky" rel="nofollow - - So what amI doing wrong? I tried to upload the file here but that didn´t work so I put the download link for those who want to take a look at the file : https://dl.dropboxusercontent.com/u/8906158/mojdeo.dwg" rel="nofollow - PS: I tried with two different computers and got the same result
Thanks in advance and best regards to you all
Miro (autocad 2014)
