Print Page | Close Window
Insert
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10444
Printed Date: 27.Oct.2026 at 16:40
Topic: Insert
Posted By: GreenForest
Subject: Insert
Date Posted: 07.Jul.2014 at 19:16
I am using AutoCad  2009 Lte.   When I am using the insert command
the pop up window allows me to choose the symbol/block to insert along with available options.  But after I insert and use the right click
(mouse)  the pop up window occurs again.  How can I just right click and insert the same symbol again as needed without the pop up window?
thanks  H. Hampton.
HWH
Posted By: John Connor
Date Posted: 07.Jul.2014 at 20:32
You can't.  Just copy the first symbol you inserted as there is no real need to keep inserting the same symbol over and over again in the same drawing.
<<AutoCAD 2015>>
Posted By: edwinprakoso
Date Posted: 08.Jul.2014 at 05:32
You can just copy existing block as mentioned by John.
Or you can select the block, right click... choose add selected from contextual menu.
Edwin Prakoso
http://cad-notes.com" rel="nofollow - CAD notes | CAD tutorials and best practices
