Print Page | Close Window
Change Color of all objects to specific colors
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10464
Printed Date: 17.Jul.2026 at 11:33
Topic: Change Color of all objects to specific colors
Posted By: Pigtoss
Subject: Change Color of all objects to specific colors
Date Posted: 16.Jul.2014 at 20:18
Hello,
In many of my drawings, there colors have been set to "red" or "yellow". However, when we print these drawings, our plot settings just change these colors to just black.
I wondering if there is a way to quickly select all objects that are "red" and change them to "color 10". And also repeat for objects that are "yellow", "green", etc...
Or perhaps someone has made a LSP program already?
Thanks,
Brad
Posted By: John Connor
Date Posted: 16.Jul.2014 at 23:39
Perhaps QSELECT?
A quick search re: lisp routines for changing the color property of any given entity shouldn't be too difficult to find.
<<AutoCAD 2015>>
Posted By: ssolkar
Date Posted: 18.Jul.2014 at 07:08
JUST GO TO PLOT STYLE TABLE,
ASSIGN YOUR COLOR.
Posted By: thinker
Date Posted: 26.Jul.2014 at 06:08
I am using this lisp for this purpose from a long time, I forget the source of this lispSmile
http://www.cadforum.cz/forum_en/uploads/381267/Change_Colour.LSP" rel="nofollow - uploads/381267/Change_Colour.LSP
Posted By: Pigtoss
Date Posted: 29.Jul.2014 at 00:09
To call this LSP, do you just type "cx"?
Posted By: jiteshnakum86
Date Posted: 29.Jul.2014 at 18:00
Hello,
Please check your plot style in plot manager, may it was settled as a "monochrome" for plot properties.
If it was just changed into "None"
Thanks
Jitesh
Warm Regards,
Jitesh Nakum
Manager
Larsen & Toubro Ltd
Posted By: philippe JOSEPH
Date Posted: 30.Jul.2014 at 07:15
Hello Pigtoss, what I know about LISP files is that you have to UPPLOAD them in your file to be treated then :
Launch the associated command.
I don't know that LISP and i have searched in the LISP file but not found the command.
Maybe "thinker" will help you ( us ).
Please tell me if this helped or not.......
Tell us about the good or bad use of this LISP and if you have succeeded in treating your files OK.
Posted By: thinker
Date Posted: 02.Aug.2014 at 06:14
Yes, to call this LSP just type cx. in any of *.lsp file the wording after "defun C:" is command of that lisp, you can change these words as your convenience but be sure that it does not conflict with other commands.
to load lisp files http://www.cadforum.cz/cadforum_en/how-to-load-install-a-lisp-application-in-autocad-tip7245" rel="nofollow - THIS  will help you.
Posted By: mmkkmmv
Date Posted: 20.Jan.2015 at 06:09
Go to https://www.youtube.com/watch?v=ojylu6iZ8YM
and download the .arx file at address below
Posted By: mmkkmmv
Date Posted: 20.Jan.2015 at 06:11
Go to below address:
https://docs.google.com/file/d/0B5YdrO75D-xYUGVxYUJFM1NpZnM/edit?pli=1
and download .arx file for autocad 2010
Posted By: mmkkmmv
Date Posted: 20.Jan.2015 at 06:14
Go to the below address:
