STL-output
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10475
Printed Date: 07.Sep.2026 at 13:16
Topic: STL-output
Posted By: mina00
Subject: STL-output
Date Posted: 20.Jul.2014 at 18:02
Hello everyone I want to save a solid in Autocad with STL format. half of my solid should be drawed in negative Y - direction. But when i save in STL format one error appear.
I don't know how save it with STL format?? have everyone a suggestion?? please guide me. thanks.
Posted By: John Connor
Date Posted: 20.Jul.2014 at 21:14
What kind of error are you getting?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: mina00
Date Posted: 21.Jul.2014 at 15:14
Hi, This error appear: The solid does not lie in the positive XYZ octant. In Autocad 2007, this error appear, but in Autocad 2015, the program automatically correct it and save the solid in positive Y- direction.But, this should not happen. I attached my related file. http://uplod.ir/4x3ytk961s6h/Drawing1.dwg.htm Thanks.
Posted By: mina00
Date Posted: 21.Jul.2014 at 15:18
Hi, This error appear: The solid does not lie in the positive XYZ octant. In Autocad 2007, this error appear, but in Autocad 2015, the program automatically correct it and save the solid in positive Y- direction.But, this should not happen. I attached my related file. http://uplod.ir/4x3ytk961s6h/Drawing1.dwg.html
Thanks.
