Print Page | Close Window
CAD weird problem
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10518
Printed Date: 06.Sep.2026 at 03:48
Topic: CAD weird problem
Posted By: woldomousavi
Subject: CAD weird problem
Date Posted: 26.Jul.2014 at 18:14
Hi
lately i had a weird problem in CAD .
i was using CAD 2012 for years and it was fine .
then someone send me a newer version of CAD 2014 and i was forced to install it .
it was fine for 2 or 3 days then one time i couldnt use any ribbons with click  .
it means that i can use commands , although autocad crashes after a while and the top ribbon fades .
i uninstalled with every program you name and installed back to 2012 version , i did a lot of things but nothing works , every version of cad has the same problem . i even erase the traces in programdata folder and registry but didnt work .
so help me , i am out options .
Posted By: John Connor
Date Posted: 27.Jul.2014 at 11:53
Are you saying you followed the uninstall procedure as recommended by AutoDesk then reinstalled 2012 and the problem still persists?
<<AutoCAD 2015>>
Date Posted: 28.Jul.2014 at 10:44
Hi and thank you for reply .
yes i Did uninstalled exactly as Autodesk said and the problem exist .
sometimes it crashes and want to send an error report too .
it is an unexpected error .
Unhappy
Date Posted: 28.Jul.2014 at 11:44
What are your system specs?
When you reinstalled did you disable your anti-virus program?  Did you also disable the UAC?
<<AutoCAD 2015>>
Date Posted: 28.Jul.2014 at 12:21
Of course i did .
i DID tell that i had AutoCAD 2012 and it worked for years .
i didnt have any problem .
now all Autocad programs crash .
Date Posted: 28.Jul.2014 at 18:33
Then it sounds like a problem with the Windows Registry.  Wipe the drive and start all over.
<<AutoCAD 2015>>
