Insert Architectural dwg into LDD dwg
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10769
Printed Date: 05.Sep.2026 at 00:03
Topic: Insert Architectural dwg into LDD dwg
Posted By: jsi1994
Subject: Insert Architectural dwg into LDD dwg
Date Posted: 04.Nov.2014 at 02:58
When I insert an architectural dwg into ldd drawings and explode the the architectural dwg, the dimension labels will not scale (1/12) down to the decimal unit size in the ldd dwg. Is there a way to load architectural object enabler into ldd dwg that will solve this problem. I am using LDD 2009.
------------- JSI
Posted By: John Connor
Date Posted: 04.Nov.2014 at 17:17
What makes you think an enabler will solve the problem?
What program was used to create/save the architectural drawing originally?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: jsi1994
Date Posted: 04.Nov.2014 at 21:01
A vendor told me that this was the way to handle this. I have not tried it. I usually bring architectural into my ldd 2009, scale 1/12, explode dimensions, and erase dimensions. Most of my architectural dwgs were created in autocad or architectural desktop. Is there a way to retain dimensions from architectural units to decimal units at the same drawing scale im working in (decimal units)
Thanks
------------- JSI
