Print Page | Close Window
Hatch is not showing in some areas, just gray out?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10845
Printed Date: 17.Jul.2026 at 21:21
Topic: Hatch is not showing in some areas, just gray out?
Posted By: bijano
Subject: Hatch is not showing in some areas, just gray out?
Date Posted: 10.Dec.2014 at 01:07
I am inserting grass and asphalt hatches throughout my cad drawing and for some reason only showing gray in two areas. Same scale and so on. Using Autocad 2015.Confused
Cadguy NW
Posted By: John Connor
Date Posted: 10.Dec.2014 at 11:16
Is all the hatching on one layer?
<<AutoCAD 2015>>
Posted By: bijano
Date Posted: 10.Dec.2014 at 18:25
Yeah its on the same layer. When I select other areas on the site plan the hatch appears normal in the preview, but in this area it just become flat gray. The only way I can get it to appear properly is by turning it to annotative and then make the scale super small. .0625
But, when I put it in without changing the annotation, properties are all the same, same layer and so on. Its really frustrating.
Cadguy NW
Date Posted: 10.Dec.2014 at 19:45
Can't you toggle the Annotative feature of that hatch pattern off?  As a matter of fact you can.  Click on the hatch pattern and when the hatch contextual Ribbon appears deselect the Annotative option.
<<AutoCAD 2015>>
