Print Page | Close Window
Different load cases in Revit Structure
Printed From: CAD Forum
Category: EN
Forum Name: Revit
Forum Description: Discussion about the BIM application Autodesk Revit (Architecture, Structure, MEP), Autodesk Forma
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10848
Printed Date: 16.Aug.2026 at 00:57
Topic: Different load cases in Revit Structure
Posted By: JTS
Subject: Different load cases in Revit Structure
Date Posted: 11.Dec.2014 at 06:08
We have different load cases to be applied at same place in structure. It is both time consuming and confusing while applying graphically. Is there any easy way for doing this?
In Staad.Pro we use staad editor to do so by copying the load case and editing load datas. Similarly we can link SAP with excel for giving different load cases easily.
